Lenovo IdeaPad Y580-2099 Daughterboard Replacement
  1. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Daughterboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
    • Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
    • Quickly survey and make sure all screws on the back panel are removed from the device.
    • Some of the screws may have been removed in previous steps.
  7. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide the disc drive out.
  8. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three M2 x 3 mm long screws circled in red.
  9. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift open the top panel carefully as there are wire cables secured to the motherboard.
  10. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After locating the cable holding the top panel in place, carefully unhook the handle using precision tweezers.
    • Carefully remove the top plate.
  11. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the top plate is removed, locate the daughter board. (Highlighted in Red).
  12. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic spudger or precision tweezers to carefully unhook the daughterboard cables.
  13. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two M2.5 x 3 mm long screws that secure the daughterboard.
  14. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check and make sure all screws and cable wires are detached before attempting to remove the daughterboard.
    • Carefully remove the daughterboard.
Jeryn Fast
crwdns2935283:004/12/22crwdne2935283:0
463 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Beck Spring 2022 crwdns2935289:0IUPUI, Team 1-1, Beck Spring 2022crwdne2935289:0
IUPUI-BECK-S22S1G1
crwdns2942667:0crwdne2942667:0 227
