Lenovo IdeaPad U430 Touch Battery Replacement
  1. Lenovo IdeaPad U430 Touch Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad U430 Touch Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad U430 Touch Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
Zach Cossey
crwdns2935283:009/20/16crwdne2935283:0
360 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G6, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S2-G6, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S2G6
crwdns2942667:0crwdne2942667:0 7,532
