Lenovo IdeaPad U350 RAM Replacement
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Lenovo IdeaPad U350 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Lenovo IdeaPad U350 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push retention clips outward and then gently slide out of slot
  4. Lenovo IdeaPad U350 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove white and black wires to make room to remove the second RAM module.
  5. Lenovo IdeaPad U350 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
James Morizzo
crwdns2935283:009/29/14crwdne2935283:0
499 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-4, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G4
crwdns2942667:0crwdne2942667:0 1,066
