Use this guide to replace or remove the keyboard on a Lenovo IdeaPad S340-15IWL laptop.
If your device is not registering keyboard clicks, the letters are not appearing on the screen, or your keys stick, it may indicate that your keyboard needs to be replaced or cleaned.
Make sure to consult the troubleshooting page before beginning the replacement as there is a chance that your keys may be obstructed, your drivers may be damaged, or the keyboard settings may have been changed.
Ensure that there is no food or liquids nearby while conducting the repair because your computer’s internal components will be exposed.
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Slide a plastic opening tool underneath the back case near the screen hinges.
Gently pry up on either side of the case.
Make sure when replacing the back cover to use the Small T5 Screw under the track pad or else the longer ones will make it so the pad wont click.
Disconnect the battery cable by gently pulling it straight out of the connector.
Remove the battery from the laptop.
What's the battery part number?? Can you provide a full battery label please?
Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
Using a spudger, gently disconnect the fan's cable from the motherboard.
Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
Carefully pick up the fan by the corners and detach the small connector wire by pulling parallel to the device.
Remove the fan from the laptop.
Unplug the wire connecting the speakers to the motherboard.
Remove the speakers from each side of the laptop.
Remove the four 3 mm screws holding the hard drive expansion slot in place using a Phillips #0 screwdriver.
Using the opening tool, gently pop off the metal cover for the RAM stick.
Using your thumbs, gently pull the two metal prongs that secure the RAM outwards.
Remove the RAM from the laptop.
Remove the three 3 mm screws that secure the black heat sink near the top of the computer using a Phillips #0 screwdriver.
Lift the heat sink vertically to remove it from the laptop.
Using an opening tool, carefully flip up the retaining flaps holding the silver video cable in place.
Slide the ribbon cable out of each connector.
Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
Gently lift the Wi-Fi card out of the computer.
Using an opening tool, flip up the retaining flap that holds the connector to the thin black ribbon cable at the bottom of the motherboard.
Gently remove the ribbon cable from its connector.
The cable is folded over and connected to itself with an adhesive. Be careful to only pull at the top fold of the cable.
Remove the three total silver 6 mm screws from the hinges of the screen in the top corners of the device using a Phillips #0 screwdriver.
Use an opening tool to flip up the hinges.
Remove the three 3 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
Carefully unplug the black and red wires connected to the upper right corner of the motherboard.
Carefully lift the motherboard from the base of the computer and remove it from the laptop.
Remove the three total silver 6 mm screws from the hinge of the screen in the top right corner of the device using a Phillips #0 screwdriver.
Unplug the charging port cable by sliding it out of its motherboard socket.
Remove the charging port by pulling vertically at the base of the wires.
Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
Remove the CMOS battery from the laptop.
Remove the silver 6 mm screw holding the USB and SD card slots in place in the upper left corner of the device using a Phillips #0 screwdriver.
Remove the black 3 mm screw holding the USB and SD card slots in place in the upper left corner of the device using a Phillips #0 screwdriver.
Use an opening tool to pry the port out of the device.
Pry up the metal plate covering the keyboard using an opening tool.
The keyboard will likely be held in place by a series of plastic pegs. These pegs are not designed to be removed, and must be broken or scraped off.
Hi, after breaking them is it possible to put glue to reattach the plate to them?
Unthread the wide black plastic cable through the slot of the metal plate.
Gently push up on the keyboard from underneath the device to separate it from the plastic casing.
Remove the keyboard from the laptop.
crwdns2947412:07crwdne2947412:0
I would say that the best repair for a keyboard replacement on this laptop is to replace the entire top cover with the keyboard attached to the plastic pegs and top cover assembly.
I've done a lot of these for quite a few customers and they always come back complaining that the keyboard was bouncy after replacement.
Well, that would be because there are no screws to bolt the laptop to the chassis, and where the complete machined part assembly of the top cover can give you a perfect repair.
Sure its more expensive and more work, but it will help the customer out the most in the long run. If you're doing this repair yourself, feel free to do the keyboard only, but if you're doing it professionally for a client; Get a complete top cover assembly.
I've done a keyboard replacement on this same laptop twice. The first attempt I replaced only the keyboard, found it bouncy and my wife hated it. I attempted to order the keyboard and cover from Lenovo only to get the run around from them for 3 months and then have them tell it was discontinued. Then the replacement keyboard failed and we just kind of gave up on the laptop and it sat in a cabinet for a few years. I don't recall why the replacement failed. Fast forward and I find myself needing a Windows machine and the specs on our Lenovo are still competitive so I decided to replace the keyboard again. The second time, I used JB Weld PlasticWeld and with a toothpick (and some canned veggies to keep the surfaces flat and pressed together) dabbed the epoxy onto where each plastic peg used to be. Assuming it holds, the new repair job doesn't feel bouncy.
Hi
Does anyone have a link to purchase a reliable replacement parts for the keyboard/top cover?
Thanks for the guide...it proved very helpful in cleaning out the keyboard. My wife seemed to think the laptop sitting on the kitchen counter while reading a recipe was a great idea, until the sauce landed on the keyboard. Next time I hope she sticks with the tablet. Hopefully it won't be to bouncy without the plastic supports. There's probably enough plastic left to use a soldering iron and melt some of the pegs to offer more strength.
Thank you for the guide. However, I've decided to sent my laptop to the professional. Just to replace a keyboard need to dismantle everything. Not worth my time.
@wtherrodjr After applying JB Weld PlasticWeld, I assume this will likely be the final repair possible. Any future attempts may make it difficult to remove the keyboard cover. Based on my repair experience, the bouncy effect seems consistent with what has been described here. Am I correct to assume that ?
Hi Bertin, I imagine it would be difficult to remove the metal keyboard tray/cover after using Plastic Weld without damaging the metal tray holding the keyboard in place. But, ultimately, the epoxy should only contact the bottom of the palm rest in the same places where the plastic pegs were. It may be possible to remove the keyboard and tray (while damaging the tray) and ordering a used palm rest (the plastic "top" with the keyboard and touchpad mounted) off of a site like eBay to scavenge the metal tray and install a new keyboard (or the used one off of the palm rest). That would really be assuming one can't find a palm rest assembly that matches your laptop color (which was my case when Lenovo canceled my order and discontinued the part). There are definitely options. At some point the laptop will not be worth repairing or, at the very least, repairing to perfect condition (using a mismatched palm rest). One also hopes that more than one keyboard replacement wouldn't be needed.
The front center-right screw may be shorter (3.5mm) than the others (6.5mm), and may be captive in the back panel.
Brad Bell - crwdns2934203:0crwdne2934203:0
