Lenovo IdeaPad S340-15IWL Battery Replacement
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
    The front center-right screw may be shorter (3.5mm) than the others (6.5mm), and may be captive in the back panel.
    Brad Bell - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
    Make sure when replacing the back cover to use the Small T5 Screw under the track pad or else the longer ones will make it so the pad wont click.
    Phillip Loftus - crwdns2934203:0crwdne2934203:0
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
    What's the battery part number?? Can you provide a full battery label please?
    Ye Wang - crwdns2934203:0crwdne2934203:0
Luke Ruff
crwdns2935283:009/17/21crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Fall 2021 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Fall 2021crwdne2935289:0
WCU-VIRTUE-F21S1G3
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 7,246
