Lenovo IdeaPad S210 Touch Back Panel Replacement
  1. Lenovo IdeaPad S210 Touch Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
    For the picture displaying the two slide latches maybe demonstrate the direction they need to slide
    Christopher Graveline - crwdns2934203:0crwdne2934203:0
    Which direction should you pull the battery? (e.g., away from the device).
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  3. Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
    I think you can remove the caution, since it was removed in the previous step.
    Make sure to write the last sentence as a complete sentence.
  4. Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
    Specifying the tool used would be a great addition to this step.
    Vanessa Onyullo - crwdns2934203:0crwdne2934203:0
    I agree, and I also think you want to add action shots here.
  5. Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad S210 Touch Back Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Zack Colman
crwdns2935283:007/08/19crwdne2935283:0
906 crwdns2915208:0crwdne2915208:0
Witam ile zatok część chce pan
Mikolaj Dabrowski - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 619
