Lenovo IdeaPad G50-45 Keyboard Replacement
  1. Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the two locking tabs away from each other to unlock the battery.
    • Remove the battery from the laptop once it is unlocked to prevent any electrical damage.
  2. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three M2x6 screws on the bottom of the laptop base.
    • Use the #2 Phillips screwdriver to loosen and remove each screw.
  3. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the cover off and remove from the base.
  4. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the three M2x6 screws that secure the keyboard in place.
    • The screws are labeled with a keyboard emblem.
    • Loosen and unscrew the three M2x6 screws with the #2 Phillips screwdriver.
  5. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop right side up once the screws that secure the keyboard to the base have been removed.
    • Pry around the keyboard to loosen it apart from the laptop with the spudger, beginning at the top left corner.
    • You will hear audible "clicks" as the keyboard is separated from the base.
  6. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top of the keyboard up and forward once the top of the keyboard has been released.
    • Be VERY careful to remove the keyboard only a few inches to not damage the connecting ribbon cable.
  7. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black locking tab with the spudger to release the connecting ribbon cable.
    • Disconnect the ribbon cable by pulling it straight out.
    • Be careful to not damage the ribbon cable with the spudger.
  8. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard after the ribbon cable is disconnected.
  9. Lenovo IdeaPad G50-45 Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When installing the replacement keyboard, first insert the bottom of the keyboard into the three slots of the base.
    • Complete the keyboard installation by pressing down on the top of the keyboard until you hear the clips snap back into place.
crwdns2935229:08crwdne2935229:0
Saulo Gomes
crwdns2935283:010/26/15crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-6, Shastany Fall 2015 crwdns2935289:0UMass Dartmouth, Team 2-6, Shastany Fall 2015crwdne2935289:0
UMASSD-SHASTANY-F15S2G6
I had an issue with the numbers at the top of alphabets. Some keys didn't work. I followed the instructions above to clean up the keyboard and hoped that would work. I could successfully remove and reassemble the keyboard but that didn't solve it.
I read it somewhere that this could be a hardware issue and the whole keyboard needs to changed. Is it really the case? Can't few keys be changed or fixed somehow?
Thank you.
Pritam Patil - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,857
