If you're looking to replace or upgrade your SSD for your Lenovo IdeaPad Flex 5 Chrome 13ITL6 this is an easy step by step guide to follow. The following tools will be needed to complete this guide.
This guide is estimated to take 5-10 minutes.
Flip the computer over to have access to the bottom.
Remove the 9 screws on the back with the T5 screwdriver.
Use a plastic opening tool to open up the back of the device, which will require some pressure.
Locate the SSD on the right side of the computer.
Remove the Phillips #00 screw.
To remove the SSD, lift where it was screwed in and gently pull it free.
