Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement
  1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Cooling Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
  8. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the blue tab to disconnect the large ribbon cable.
    • Pull on the blue tab to disconnect the small ribbon cable.
  9. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to disconnect the speaker plug on the right of the motherboard.
    • Pull the speaker towards you and it will disconnect from its mount.
    • Pull up on the Wi-Fi card wire connections, and move them aside.
  10. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4 mm motherboard screws with a Phillips #1 screwdriver.
  11. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2 mm screws from the right hinge using a Phillips #2 screwdriver.
    • Disconnect the screen cable connector.
    • Remove the motherboard from the laptop.
  12. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2 mm screws from the touch-pad bracket using a Phillips #0 screwdriver.
    • Pull the bracket up and out of the frame of the laptop.
Jonathan Baldo
crwdns2935283:010/16/24crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-6, Konn Fall 2024 crwdns2935289:0UMass Dartmouth, Team 1-6, Konn Fall 2024crwdne2935289:0
UMASSD-KONN-F24S1G6
crwdns2942667:0crwdne2942667:0 321
