Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement
  1. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4mm screw with a JIS #0 screwdriver.
  4. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable.
  5. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the existing USB hub and replace it with the new hub.
Elijah Ellis
crwdns2935283:011/08/18crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 crwdns2935289:0UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018crwdne2935289:0
UMASSD-GULBRANDSEN-F18S5G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 434
