Lenovo IdeaPad Flex 4-1470 RAM Replacement
  1. Lenovo IdeaPad Flex 4-1470 RAM Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
    I have to know how long the pins are in the clips that hold the hinges in place. I don’t want to destroy my tablet.
    otlerelron - crwdns2934203:0crwdne2934203:0
    Mine had ten tiny little star screws. Not Phillips.
    Justen Hansen - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad Flex 4-1470 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.16
    • RAM cards can be damaged from exposure to a static charge through contact with the hand or other body parts. Though the damage of one discharge is not severe, multiple exposures can cause your RAM to fail.
    • When changing the RAM please wear an anti-static wrist strap on your dominant hand and attach the alligator clips to one of the screw holes in the laptop body.
    • Using a metal spudger, pry the RAM cover out of the clips on the motherboard. You will need to go around all sides.
    • Remove the cover.
    • When replacing the cover make sure it is in all of the clips.
  4. Lenovo IdeaPad Flex 4-1470 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the RAM card simply pull the clips on the sides outwards and the RAM will tilt up.
    • Gently pull the RAM out of the motherboard.
    • When inserting a new RAM card, ensure you put it in at an angle just like it came out. Then push it down into the clips.
crwdns2935229:010crwdne2935229:0
Demario Robinson
crwdns2935283:010/02/17crwdne2935283:0
1 047 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S1-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S1G6
crwdns2947412:05crwdne2947412:0
I am an older lady and I know I couldn;t possibly do that,do you have any advice
diane nodwell - crwdns2934203:0crwdne2934203:0
To Diane: Take your device to Best Buy Geek Squad or to Device Pit Stop. Otherwise, Do you have a skilled nephew / neighbor who can replicate this?
Raul Soria - crwdns2934203:0crwdne2934203:0
Can you please confirm if the DDR4 PC4-21300 RAM is accepted by the Flex4? Thanks!
SIW shows as if there are two memory slots.
Serg Strikov - crwdns2934203:0crwdne2934203:0
Hey there,
Any suggestions on which RAM card to buy to replace this one? I have 2 GB of RAM now that came with the laptop and I obviously want to replace it to try and speed up my Lenovo. Will it damage the laptop if the RAM is “too much” for the pc? Can I find a single RAM card that is more than 8 GB or faster? What GB do you suggest for faster speeds?
Thanks for your help.
Christine Portanova - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 10,188
