Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Elijah Ellis
crwdns2935283:011/08/18crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 crwdns2935289:0UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018crwdne2935289:0
UMASSD-GULBRANDSEN-F18S5G2
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 1,444
