Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement
  1. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
    I have to know how long the pins are in the clips that hold the hinges in place. I don’t want to destroy my tablet.
    otlerelron - crwdns2934203:0crwdne2934203:0
    Mine had ten tiny little star screws. Not Phillips.
    Justen Hansen - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm Phillips #0 screws holding the hard drive in place.
    • Note: A security sticker is normally affixed to the upper-right screw that helps hold the drive in the machine.
  4. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive by pulling it out of its port (away from the hinges).
    • It's normal to feel a lot of resistance, especially if this is the first time the hard drive is being removed. Just ensure that you have removed all three screws.
  5. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3 mm Phillips #0 screws located on opposite sides of the hard drive.
    • These screws hold the hard drive in the hard drive mounting bracket. All computers use a hard drive mounting bracket because the standard holes on hard drives are not in a convenient place for direct mounting. All laptop hard drives will fit in any laptop's mounting bracket but the brackets are specific to the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive from the mounting bracket.
crwdns2935229:018crwdne2935229:0
Heeral Patel
crwdns2935283:010/02/17crwdne2935283:0
418 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S1-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S1G6
Thanks for posting! Any suggestions on the best means to transfer (mirror) the old to new drive?
Douglas Henningsen - crwdns2934203:0crwdne2934203:0
This guide comes up when I click on “keyboard replacement.” Is there a guide for keyboard replacement? A search does not find one.
Greg Worrel - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 9,291
