Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement
  1. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shut down your Chromebook completely. Unplug the charger and anything else connected. Flip the device over and place on a flat surface.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with your PH00 screwdriver and remove all of the 7x(M2x4.5mm) indicated screws. These screws keep the screen in place. Once removed, take the screen off.
    • The marked cord needs to be disconnected too, this is the screen cord to the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 9 sets of screws (M2x4) that secure the motherboard in place, which need to be removed. One screw is hidden under a small Lenovo sticker, marked in orange. Removing the sticker will reveal that the motherboard has been repaired.
    • Each screw securing the motherboard is marked with a small triangle, which helps identify the correct screws for reassembly, as some holes require multiple layers to be screwed together.
    • The two rectangles represent cords that connect the main motherboard to the side motherboards. For our purpose, disconnect the cord marked in blue.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After completing the last step, you can now easily remove the motherboard.
    • Plug in your soldering iron and set it to approximately 350°F.
    • Be cautious to avoid burns, and always use a proper stand. Keep the soldering iron away from flammable surfaces.
    • Flip the motherboard over and carefully desolder the small holes using the tip of your heated soldering iron. This will melt the solder, allowing you to remove the USB-C port.
    • Position the new USB 3.1 Type-C 16-pin female connector in place, then reheat the solder to secure it to the motherboard.
    • Plug the battery back into the motherboard. Carefully snap the back cover into place. Reinstall all screws to secure the cover. Plug in your charger and check if the Chromebook powers on and charges properly. If everything works, you're done!
To reassemble your device, follow the instruction.
Arian Esfandiari
crwdns2935283:002/09/23crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-2, Saru Jimmy Spring 2023 crwdns2935289:0University of North Texas, Team 3-2, Saru Jimmy Spring 2023crwdne2935289:0
UNT-SARU JIMMY-S23S3G2
crwdns2942667:0crwdne2942667:0 552
