Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement
  1. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Lenovo IdeaPad Flex 3 CB 11M735: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shut down your Chromebook completely. Unplug the charger and anything else connected. Flip the device over and place on a flat surface.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 4.5 mm screws using a Phillips #00 screwdriver.
    • Disconnect the display cable from the motherboard.
    • Remove the display from the laptop.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 4 mm screws from the motherboard using a Phillips #00 screwdriver.
    • Each screw securing the motherboard is marked with a small triangle, which helps identify the correct screws for reassembly, as some holes require multiple layers to be screwed together.
    • Disconnect the ribbon cable from the motherboard.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 3 CB 11M735 Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard from the laptop.
    • Plug in your soldering iron and set it to approximately 350°F.
    • Be cautious to avoid burns, and always use a proper stand. Keep the soldering iron away from flammable surfaces.
    • Flip the motherboard over and carefully desolder the small holes using the tip of your heated soldering iron. This will melt the solder, allowing you to remove the USB-C port.
    • Position the new USB 3.1 Type-C 16-pin female connector in place, then reheat the solder to secure it to the motherboard.
Arian Esfandiari
crwdns2935283:002/09/23crwdne2935283:0
421 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-2, Saru Jimmy Spring 2023 crwdns2935289:0University of North Texas, Team 3-2, Saru Jimmy Spring 2023crwdne2935289:0
UNT-SARU JIMMY-S23S3G2
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 717
