Batteries wear over time. It is not uncommon for the battery to eventually die out. This guide will help you replace the battery of the Lenovo IdeaPad Flex 3 Chromebook (11M735).
Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
Using a plastic spudger, carefully lift the palmrest from the bottom cover.
Disconnecting the battery from the motherboard.
Use a PH00 screwdriver to remove the 3x(M2x4mm) screws.
Ensure the replacement battery is right, then follow the steps backward to assemble everything.
