Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement
  1. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any accessories such as the detachable keyboard from the device.
    • Power the device off by pressing and holding the power button for about three seconds.
  2. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger into the ridge between the screen and the back of the device, creating a small gap.
    • Run the spudger along the edge of the screen and around the corners to separate the screen from the rest of the device.
    • Be careful not to use more force than necessary with the metal spudger or else the device could potentially be scratched.
    • Do not fully lift or pull the screen away from the device once it is loose because the internal connectors are still attached.
  3. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the small tab on the orange connector.
    • Separate the screen from the back of the device.
  4. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two pieces of electrical tape securing the battery.
    • Expect some resistance as you pull on the tape to remove it.
    • If the tape is not reinserted correctly during reconstruction, the device may not be able to power on again. Keep this risk in mind and try not to damage the tape.
  5. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3 mm screws from the metal bracket securing the battery connector using a Phillips #00 screwdriver.
    • Remove the metal bracket.
  6. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the connector and remove the old battery.
Judah
crwdns2935283:003/17/25crwdne2935283:0
333 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Rioux Spring 2025 crwdns2935289:0UMass Dartmouth, Team 1-1, Rioux Spring 2025crwdne2935289:0
UMASSD-RIOUX-S25S1G1
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 283
