Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement
  1. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the bottom cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the bottom cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all 10 T5 screws. The screws are all the same length.
    • Remove the bottom cover carefully. Maybe it is necessary to use a pick or spudger.
  2. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Disconnect and remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Disconnect and remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Disconnect and remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws holding the battery an disconnect it.
  3. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove speakers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove speakers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the left speaker.
    • Untangle the cable connecting the left and right speakers (the pass under the protector covering the touchpad).
    • Disconnect the right speaker from the mainboard and pull it up to remove the two speakers.
  4. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Disconnect the antenna cables and adapter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the antenna cables by pulling them upwards. You might find this easier using tweezers.
    • Remove the screw holding the WiFi module and remove the module.
  5. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the ribbon cables of the keyboard assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the plastic tabs holding the ribbon cables.
    • Pull out the ribbon cables horizontally. Do not pull on the ribbon cables vertically or with any significant force.
  6. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Disconnect the display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the plastic tab holding the display cable up.
    • Pull the display cable out horizontally. Do not pull on the cable vertically or with great force!
  7. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Unscrew display assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 PH0 screws (all the same length) holding the display assembly to the keyboard assembly.
  8. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Unscrew daughterboard on the left side: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one screw holding the daughterboard on the right side.
  9. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Unscrew mainboard on the right side: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 screws on the right side of the motherboard.
  10. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the plastic placeholder: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 screws holding the plastic placeholder in place.
    • Remove the placeholder.
  11. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove the fan: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws holding the fan.
    • Disconnect the fan from the mainboard.
    • Untangle the antenna cables from the fan and remove the fan.
  12. Lenovo IdeaPad 530S-14IKB Keyboard / touchpad assembly Replacement, Remove and replace the keyboard / touchpad assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop hinges to a 45-60 degree angle. This can be done the easiest by carefully opening and then closing the laptop.
    • Untangle the network antenna (on the left) and the display cable (on the right) from the keyboard assembly.
    • Remove the keyboard assembly and put in the replacement one.
Wooing Snowdrift
crwdns2935283:007/30/23crwdne2935283:0
400 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 161
