Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition
  1. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 2 Loosen the back cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 3 Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Step 6 Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  7. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Unfasten the SATA drive bracket: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the remaining two screws securing the SATA drive bracket.
  8. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Locate the SATA drive connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The SATA drive connector is below the Wifi adapter and to the right of the M.2 NVME slot.
    • It is the second left connector.
  9. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Prepare SATA drive connector: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the flat cable connector.
  10. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fold the SATA ribbon cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the cable.
  11. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Insert the SATA drive ribbon cable connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the cable in with the blue/non-contact side facing up.
  12. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Close the SATA drive connector: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lower the flat cable connector.
  13. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Note the orientation of the SATA data and power connectors: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the example, the power is on top, and data is on the bottom. You'll need to install your SATA drive in the correct orientation.
  14. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the SATA drive in the bracket: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the orientation.
  15. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Fasten the SATA drive to the bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 4 screw mount points.
  16. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Connect the drive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the SATA drive to the connector.
  17. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the drive in the chassis: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the SATA drive in.
  18. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Place the battery in the chassis: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the battery in.
  19. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Refasten the bracket and the battery: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to fasten the six screws securing the SATA drive bracket and battery.
  20. Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 5 15ITL05 SATA Drive Replacement/Addition, Reconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery connector back into place.
E N
crwdns2935283:011/21/22crwdne2935283:0
530 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 1,139
