Lenovo IdeaPad 330S-15ARR Touch Pad Replacement
  1. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
    • Use a Jimmy or your fingernail to pry the back panel off.
  2. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 3 mm screws securing the battery using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect the battery connector from the motherboard by pulling the plug straight out to avoid bending the pins.
  4. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out of its compartment and set it aside.
  5. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Hard Drive Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Hard Drive Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Hard Drive Assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
  6. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the hard drive down in place.
  7. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Jimmy to remove the blue and black bracket that surrounds the hard drive.
    • Pull the hard drive from the bottom to release it from its black port labeled S0712.
  8. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black board.
  9. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black electrical tape from the fan.
  10. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan from the circuit board by pulling on the plastic part of the wire towards the fan.
  11. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
  12. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan to remove it from the laptop.
  13. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement, Touch Pad: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 3 mm screws connecting the motherboard to the frame of the laptop.
  14. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Wi-Fi card by pulling it out to the right.
    • Detach the black cable from the motherboard.
  15. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the top right of the motherboard down and left.
    • Make sure there is enough clearance for the USB ports on the right to not be damaged as they can interfere with the case if not pushed in enough.
  16. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1.5 mm silver screws using a Phillips #00 screwdriver.
    • Remove the three 1.5 mm black screws using a Phillips #00 screwdriver.
  17. Lenovo IdeaPad 330S-15ARR Touch Pad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the silver bar holding down the frame to the touchpad, and remove the gold tape.
    • Remove the frame and pull straight up on the touch pad to remove it.
Jacob McPhee
crwdns2935283:010/16/24crwdne2935283:0
291 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Konn Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-4, Konn Fall 2024crwdne2935289:0
UMASSD-KONN-F24S2G4
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 105
