If you are having trouble with your Lenovo IdeaPad 330S-15ARR hard drive or you want to upgrade to a faster one or a larger storage one, this is the best guide for you.
Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the hard drive down in place.
Use a Jimmy to remove the blue and black bracket that surrounds the hard drive.
Pull the hard drive from the bottom to release it from its black port labeled S0712.
Remove the two 4 mm screws (four total) from each side of the hard drive bracket using a Phillips #00 screwdriver.
Lift the silver case and replace the hard drive with your new hard drive.
