If your Lenovo IdeaPad 330S-15ARR laptop is overheating, making loud disrupting noises, or just not working, follow this guide for step-by-step instructions on how to replace the fan.
Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
Remove the black board.
Remove the black electrical tape from the fan.
Disconnect the fan from the circuit board by pulling on the plastic part of the wire towards the fan.
Remove the five 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
Lift the fan to remove it from the laptop.
