You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and will require opening the device. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you turn off the device wait 5 minutes.
If you live in area rich of Static Electricity please advise using an ESD Strap.
Please turn off the laptop before opening the device
Remove the 10 screws as shown in the picture.
Gently using the tool pry off the bottom case
Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
Remove these screws as show in picture
Gently pry out the black case.
Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
Before removing the case, for safety you have to disconnect the battery cable, otherwise you may damage the motherboard when you touch it with the case.
Thank you for reminding it. The repair guide have been updated.
In my case - only 3 screws have to be removed. The top screw is under cover and no need to remove it. Lenovo 330s-15lkb
Gently using heavy duty spuder remove the old memory
If you dont have a heavy duty spudger you could use your nails to remove the memory module.
Arrange the new ram stick accoring the pin on the motherboard
Push Gently on the stick until you hear two clicks
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
crwdns2947412:08crwdne2947412:0
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
You can disconnect the battery no need of removing it.
I just Updated the repair guide of memory replacement.
I think I can do it well. Thank you.
Brilliant guide! The black case covering my RAM module was slightly different but the principle is the same. Thanks for stating the tools needed and having clear pictures and easy-to-follow instructions!
Thank you for the support. my ideapad 330S originally was i5 8520U and got upgraded on warranty to an i7 8550U. so basically there are not that different…
