Lenovo IdeaPad 330S RAM Replacement
  1. Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Please turn off the laptop before opening the device
    • Remove the 10 screws as shown in the picture.
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S RAM Replacement, Disconnecting Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
  3. Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these screws as show in picture
    • Gently pry out the black case.
    • Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
    Before removing the case, for safety you have to disconnect the battery cable, otherwise you may damage the motherboard when you touch it with the case.
    Gastón Luna - crwdns2934203:0crwdne2934203:0
    Thank you for reminding it. The repair guide have been updated.
    Ilia Tocheny - crwdns2934203:0crwdne2934203:0
    In my case - only 3 screws have to be removed. The top screw is under cover and no need to remove it. Lenovo 330s-15lkb
    Сергей Шацкий - crwdns2934203:0crwdne2934203:0
  4. Lenovo IdeaPad 330S RAM Replacement, Removing Ram Stick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently using heavy duty spuder remove the old memory
    If you dont have a heavy duty spudger you could use your nails to remove the memory module.
  5. Lenovo IdeaPad 330S RAM Replacement, Installing Ram Stick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Arrange the new ram stick accoring the pin on the motherboard
    • Push Gently on the stick until you hear two clicks
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Ilia Tocheny
crwdns2935283:004/30/19crwdne2935283:0
1,667 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Nathan D'souza - crwdns2934203:0crwdne2934203:0
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
Muromi - crwdns2934203:0crwdne2934203:0
You can disconnect the battery no need of removing it.
Ilia Tocheny -
I just Updated the repair guide of memory replacement.
I think I can do it well. Thank you.
Brilliant guide! The black case covering my RAM module was slightly different but the principle is the same. Thanks for stating the tools needed and having clear pictures and easy-to-follow instructions!
jaron84 - crwdns2934203:0crwdne2934203:0
Thank you for the support. my ideapad 330S originally was i5 8520U and got upgraded on warranty to an i7 8550U. so basically there are not that different…
Ilia Tocheny -
crwdns2936753:030crwdne2936753:0 79
crwdns2942667:0crwdne2942667:0 8,297
