Lenovo IdeaPad 330S Battery Replacement
  1. Lenovo IdeaPad 330S Battery Replacement, Removing bottom panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S Battery Replacement, Removing bottom panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and disconnect it from the power supply.
    • Remove the 10 screws as shown in picture.
    • Using an opening tool pry off the bottom case.
    I've lost some screws. Can someone tell me which screws buy from internet?
    pitaref - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad 330S Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery by gently pushing the black connector to the left. (Marked in blue).
    • Remove the 5 screws that are marked in red.
    • Install the new battery.
Ilia Tocheny
crwdns2935283:004/30/19crwdne2935283:0
1.667 crwdns2915208:0crwdne2915208:0
Make sure you check if your replacement battery is the 12.25v or the 7.4v. This laptop could have came with either.
Nick Aspinwall - crwdns2934203:0crwdne2934203:0
Actually you could to upgrade your battery from 43 WHR to 52.5 WHR but this requiring little bit research…
Ilia Tocheny -
So is there a battery shaped similarly that will increase the battery life? My laptop will only last about 2 hours.
patrick charles - crwdns2934203:0crwdne2934203:0
Hi, is your battery is 52.5 Whr? Is it orginal?
If the answer to both is yes, I would recommend to replace the battery because it might be dying (wearing).
but before you change it check with the lenovo support what battery can you buy.
(support lenovo-register-detect device-parts-recharble batteries)
if that doesnt help you can always ask lenovo support specialist
Ilia Tocheny -
my 330s 15arr came with a 30wh battery and is quite degraded now lasting less than 2hrs, can I replace it with a 52wh battery? the size and mounting tabs look exactly the same
Kaizoku 62 - crwdns2934203:0crwdne2934203:0
Yes and no.. you need to check what voltage of the 30whr battery because the 52.5 is 12.4v if I’m not mistaken….
And the 30 whr is 7.4v which could harm your MB or other parts.
Ilia Tocheny - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 17,029
