Guide to safely and effectively replace the Lenovo IdeaPad 330-15AST RAM without damaging the device.
Remove the 7 mm Phillips screw from the back of the laptop that secures the optical drive in place.
Carefully slide the optical drive out of the laptop.
Remove the twelve 7 mm Phillips screw from the back of the device.
Use opening picks or a plastic pry tool to remove the cover on all sides then lift.
Pull the metal arms out slightly that hold the RAM secure by applying pressure with your finger.
