If your Lenovo IdeaPad 330-15AST is experiencing slow performance, frequent crashes it might be time to change your hard drive. Use this guide to help you replace your hard drive on the Lenovo IdeaPad 330-15AST.
Before using this guide make sure that you backup the important data that you have before replacing your hard drive to prevent any data loss.
Before you start this guide make sure that your device is completely turned off and disconnected from any power source.
Remove the 7 mm Phillips screw from the back of the laptop that secures the optical drive in place.
Carefully slide the optical drive out of the laptop.
Remove the twelve 7 mm Phillips screw from the back of the device.
Use opening picks or a plastic pry tool to remove the cover on all sides then lift.
Detach the battery connector from the socket on the motherboard.
Pull the hard drive case out to remove it.
Remove the hard drive from the hard drive case.
