crwdns2894164:0crwdne2894164:0
crwdns2890822:0crwdne2890822:0
crwdns2890844:0crwdne2890844:0
crwdns2861143:0crwdne2861143:0
crwdns2860947:0crwdne2860947:0
crwdns2890040:0crwdne2890040:0
  1. Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Open Laptop between 90 to 130 degrees.
  2. Use the blue plastic spudger to pry the screen frame away from the screen. Use your fingers to finish removing the screen frame. Gently pull the screen frame out by tilting it forward and pulling up until it is removed.
    • Use the blue plastic spudger to pry the screen frame away from the screen.
    • Use your fingers to finish removing the screen frame.
    • Gently pull the screen frame out by tilting it forward and pulling up until it is removed.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the 4 Phillips #0 screws at the 4 corners of the screen.
    • Remove the 4 Phillips #0 screws at the 4 corners of the screen.
  5. Slowly lean screen forward away from the outside cover.
    • Slowly lean screen forward away from the outside cover.
  6. Use needle nose tweezers to carefully detach the sticker from the bottom of the screen that is holding the webcam wires in place. Pull the screen out. Pull the screen out.
    • Use needle nose tweezers to carefully detach the sticker from the bottom of the screen that is holding the webcam wires in place.
    • Pull the screen out.
crwdns2892372:0crwdne2892372:0
crwdns2878426:04crwdne2878426:0
Amanda Quinn
crwdns2886885:021/09/2017crwdne2886885:0
185 crwdns2894548:0crwdne2894548:0
crwdns2882065:0crwdne2882065:0
crwdns2892814:0crwdne2892814:0
Washington State, Team S5-G7, Phelps-Hillen Fall 2017 crwdns2886886:0Washington State, Team S5-G7, Phelps-Hillen Fall 2017crwdne2886886:0
WSU-PHELPS-HILLEN-F17S5G7
crwdns2858115:04crwdne2858115:0
crwdns2886889:08crwdne2886889:0
crwdns2892924:00crwdne2892924:0
crwdns2892926:0crwdne2892926:0
crwdns2894754:0crwdne2894754:0:
crwdns2894766:024crwdne2894766:0 1
crwdns2894768:07crwdne2894768:0 5
crwdns2894768:030crwdne2894768:0 57
crwdns2894770:0crwdne2894770:0 1,680
