This guide will help to replace the SSD in your Lenovo IdeaPad 3-15IGL05. An SSD is a solid-state drive which is a storage device that use integrated circuits to store data persistently. Data is stored in memory cells within NAND flash chips. The SSD controller manages read/write operations and data distribution, so when your computer needs to access data, the controller quickly retrieves it from the appropriate cells. For writing data, the controller finds available cells and stores the information electronically.
The SSD is very important to your device's functionality so if your SSD is damaged or corrupt follow these directions to replace it. Overall, this replacement is straightforward and should be completed in a few simple steps if completed carefully and with precision. The tools you will need include iFixit opening tool, Phillips #0 screwdriver and Phillips PH000 screwdriver.
Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
Lift the bottom panel up and off the chassis.
Locate the SSD at the bottom right corner of the fan.
Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
Gently pull the SSD directly out of its port.
