Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement
  1. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
    • Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
  4. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
  5. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip each cable by using the angled tweezers and gently pull it straight out.
    • This will allow you to disconnect the black and white antenna cables from the Wi-Fi card.
  6. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.0 mm screw using a Phillips #00 screwdriver.
  7. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Wi-Fi card to the left to remove it.
Kate Zeiher
crwdns2935283:003/04/25crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-5, Frey Spring 2025 crwdns2935289:0University of Kentucky, Team 1-5, Frey Spring 2025crwdne2935289:0
UKY-FREY-S25S1G5
Hi Kate! thanks for your instruction on how to open and change the WiFi module... I have a question about the version of M.2 Key E wich are compatible with this Laptop.
The original one is a M.2 Key A+E RTL8822CE from REALTEK. I think this is giving me a problem with WHEA_UNCORRECTABLE_ERROR Blue Screen issue. So I take it off and then not problems are visibles, everything works fine.
So I take off the WiFi module from a LENOVO L340 wich it comes with INTEL 9462NGW, M.2 Key E form factor. Is not working.
I look into the respective Schematics and foun that Lenovo ideaPad 3 doesn't have some conections lines (SPI,UART,others), just USB conections... so i think there is a problem with Key E types wich wont works withs this Laptop.
So question is... Do am I ok?? Does Key E need all pins connection? I will looking for more info, so if I coul answer me will share it too here!
I hope you all community still fine! Cheers!
NicoTiza - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 204
