Use this guide to replace the RAM stick in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the RAM is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Use a Phillips #0 screwdriver to remove the six M2 x 5 mm screws located at the top half of the laptop.
Use a Phillips #0 screwdriver to remove the four M2 x 2.5 mm screws located at the bottom of the laptop.
Insert the pry pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
Slide the RAM stick out of the motherboard slot.
