Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
