A Wi-Fi card is a internal wireless terminal device within your computer that enables internet connection through the wireless connection network under the coverage of a wireless local area network. A Wi-Fi card would need to be replaced if it is affecting wireless Wi-Fi connection, which could be noticed by weak wireless internet connection or lack of wireless internet connection. This guide will lead you through removing your Lenovo IdeaPad 3-1481W000NGUS Wi-Fi card. This guide is moderately complicated, containing steps to access the internal hardware of your computer and unscrewing/connecting screw's/cables within the hardware
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Orient the laptop so that the bottom is facing up.
Remove the six 7 mm screws using a Phillips #00 screwdriver.
Remove the four 4 mm screws using a Phillips #00 screwdriver.
Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
Use your fingernail or an opening tool to gently pull out and disconnect the battery pack cable.
Use the spudger to remove each cable from the Wi-Fi card, one cable at a time.
Remove the single 2 mm screw using a Phillips #00 screwdriver.
Pull the card away from the housing capsule on the right side of the Wi-Fi card to remove it from the laptop.
