The Lenovo IdeaPad 110-171KB laptop's screen removal instructions are covered in this article. if the contents of the computer are not being displayed on your screen correctly or if it is lagging. To guarantee a good connection, the cable that attaches to the screen is often secured in place with strong tape. When reattaching, be sure to replace this tape. Take care not to harm any other inside parts.
Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
Use an opening tool to gently disconnect the clips on the side of the back panel.
Pry out the optical drive opposite of the laptop.
Release the remaining clasp and remove the lower case.
Open the laptop, make sure it is facing you.
Using a opening pick, detach the clips around screen that is holding the bezels in place.
Remove all bezels.
Remove all four 3 mm screws with the a Phillips #0 screwdriver.
Carefully disconnect the cable connector from the connecting port.
