Lenovo IdeaPad 110-15ISK Keyboard Replacement
  1. Lenovo IdeaPad 110-15ISK Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
    There’s a screw which is fixed behind the laptop which is fixed to keyboard.
    So first remove all screws on the back panel in step 5.
    Suyama Madushan - crwdns2934203:0crwdne2934203:0
    There are actually 2 screws on the bottom of the laptop that secure the keyboard. Removing all screws from the bottom of the laptop is still the best thing to do before beginning.
    Michael Wiseman - crwdns2934203:0crwdne2934203:0
  3. Lenovo IdeaPad 110-15ISK Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    Die zwei Schrauben auf der Unterseite müssen vorher gelöst werden. Wer dieser Anleitung folgt, bekommt die Tastatur zwar mit Gewalt raus, hat aber dann sie von der verschraubten Halterung abgerissen.
    schiller - crwdns2934203:0crwdne2934203:0
    Danke! Ich hab’s angepasst!
    Fabian Neidhardt -
    Do not pull on the cable. This is a ZIF connector. You will have to unlock the connector before pulling or prying on the cable. Click on the link for instructions on unlocking ZIF connectors .
    Recognizing & Disconnecting Cable Connectors
    Jeff Moore - crwdns2934203:0crwdne2934203:0
    • Unlock the ZIF conector before pulling the cable out
crwdns2935229:05crwdne2935229:0
Tyler
crwdns2935283:010/17/18crwdne2935283:0
624 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G5, Rose Fall 2018 crwdns2935289:0UW Tacoma, Team S1-G5, Rose Fall 2018crwdne2935289:0
UWT-ROSE-F18S1G5
crwdns2935297:039crwdne2935297:0
La procedura è la stessa anche su un Lenovo ideapad 110-15ACL?
Yvonne Pandolfo - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 7,705
