Lenovo IdeaPad 110-15ISK Battery Replacement
  1. Lenovo IdeaPad 110-15ISK Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Battery Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Battery Replacement, Upper Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down and gently pry the top case free from the bottom case.
  9. Lenovo IdeaPad 110-15ISK Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is attached to the bottom case of the laptop.
    • Remove the two 4.0mm screws.
    • Push the battery component away from you in order to completely remove the battery from the fixture.
Jakub Szark
crwdns2935283:010/17/18crwdne2935283:0
547 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G5, Rose Fall 2018 crwdns2935289:0UW Tacoma, Team S1-G5, Rose Fall 2018crwdne2935289:0
UWT-ROSE-F18S1G5
crwdns2935297:040crwdne2935297:0
crwdns2936753:030crwdne2936753:0 160
crwdns2942667:0crwdne2942667:0 25,603
