Lenovo IdeaPad 110-15IBR Optical Drive Replacement
  1. Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 110-15IBR Optical Drive Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
    How do we add the steps from the first time we removed the back from the computer? I keep forgetting what that is called but we need to use the same steps that we’ve used in previous guides.
    Madison Burke - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using #1 Phillips screwdriver remove the 1 (9mmx6mm) screw holding the disk drive in place.
  3. Lenovo IdeaPad 110-15IBR Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive away from device to slide out of dock.
    • Careful not to pull the drive straight up or towards the device, otherwise damage might be done to the drive connector.
crwdns2935229:05crwdne2935229:0
Saddam Alsinai
crwdns2935283:010/18/17crwdne2935283:0
687 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S3-G4, Liner Fall 2017 crwdns2935289:0UW Tacoma, Team S3-G4, Liner Fall 2017crwdne2935289:0
UWT-LINER-F17S3G4
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
Max Härtwig - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,882
