Having trouble with your hard drive? Here's some steps to replace the hard drive on the Lenovo G70-80.
Set the laptop on its front so you can see the back panel.
Remove the two placeholder screws, and then proceed to pull off the back of the laptop.
Using your Phillips Screwdriver, remove the four screws around the hard drive.
Shift the hard drive to the right and you will feel it click. That means it has been unlocked and can be removed.
