At some point in your lifetime, you'll probably end up in this situation: You own a perfectly good laptop, but you've broken the screen! By utilizing this guide, you can save yourself time and money while learning more about your computer! This guide will explain, step-by-step, how to replace the screen in your Lenovo G570 notebook computer.
Order a replacement screen for your laptop! Screens for this laptop (and almost any other model) can be found at https://www.laptopscreen.com/.
Gather the necessary tools, and make sure you have a large open space (such as a workbench) to work on.
Remove the 2 rubber bumpers which cover the screws. (They are located on the bottom left and right corners of the bezel.)
Then, using your small Philips-head screwdriver, remove the 2 screws which were just uncovered.
Remove the front plastic bezel from the screen using the following steps.
Pry up the bezel in the location depicted with a plastic opening tool or small flat-head screwdriver until you free the first few retaining clips.
Once a few clips are loosened, you can pry the bezel the rest of the way off by hand.
To do so, pull each side of the bezel outward and towards the center of the screen, until all of the retaining clips have been released.
Remove the four screws (one in each corner) which attach the screen to the lid.
Carefully pull the lid away from the screen, while keeping in mind that there are cables attached to the lid as well as the screen.
Now, detach the video cable from the back of the screen.
Remove the 8 screws (4 on each side) which attach the hinges to the screen
Remove the screen, and recycle it at your local dump or recycling center
Position the screen face-down on the keyboard, and line up the hinges with the holes on either side of the screen
Using your Philips-head screwdriver, replace the 8 screws (4 on each side)
Lift the plastic lid up to the back of the screen, and press them together so that lid now hinges with the screen
Replace the four screws that hold the screen and lid together
Snap the plastic bezel on, and replace the two screws which connect the bezel to the computer (reference step 4 for clarification)
crwdns2935229:015crwdne2935229:0
You should mention in step 7 how to recognise if screen is LED or CCFL.
