Lenovo G50-80 80E5 Removing top panel Replacement
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 3 screws on the bottom securing the keyboard in place.
    • One Screw will be located under a Lenovo security sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting on the side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue prying around the top of the keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Top covered removed
crwdns2935229:012crwdne2935229:0
Victor
crwdns2935283:010/17/17crwdne2935283:0
1,309 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 crwdns2935289:0UMass Dartmouth, Team S1-G6, Simcock Fall 2017crwdne2935289:0
UMASSD-SIMCOCK-F17S1G6
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 8,094
