Disassembly of the laptop is required to remove the power jack.
Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
Slide the tab positioned on the right side to the right.
Move the left tab to the left to release the battery.
You will hear an audible 'click' and see the battery separate from the rest of the laptop.
Hold the battery at the top seam between it and the laptop.
Roll the battery towards yourself.
Lift the battery out of the laptop.
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Slide the cover away from the hinges and lift the panel off.
Locate the CD drive.
Remove the single #00 Phillips 5.5 mm screw on the centermost side of the drive.
Move the drive towards the outside of the laptop to remove the connector.
Pull the drive out of the laptop.
Locate the 3 screws on the bottom securing the keyboard in place.
One Screw will be located under a Lenovo security sticker. Break sticker to gain access to screw.
Starting on the side, gently pry up using spudge.
Continue prying around the top of the keyboard
Once the top of keyboard is loose, gently lift up
lift up bottom of keyboard slightly, to access keyboard ribbon
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, lift up clip to remove keyboard ribbon cable.
On some laptops the colors for the clips are reversed. You should lift up the inner piece. Took me 15 mind to figure out
Keyboard ribbon cable removed
Once ribbon is removed, keyboard can be lifted out
Remove wifi wires by lifting up
The reattachment of these wires is tricky and not immediately obvious. The wires clip to the card by a small circular attachment male on the card female on the wire. I used a small flat head electrical screwdriver to push down the wires onto the card.
locate power and monitor cable on bottom side next to fan
remove power cable with tweezers by gently pullying
remove monitor cable by gently pulling on tab straight up
Monitor and power cable disconnected
Disconnect the fan wires from the motherboard by lifting upwards
Locate the 3 screws holding fan in place
Remove 3 screws
fan should lift out of place
lift clip to remove ribbon cable for think pad.
lift clip to remove power button ribbon cable.
Begin by locating screws on bottom panel
Missing step. The hard drive needs to be removed. 4 screws then slide back (to left in above image)
Remove screws using a 001 phillips screw driver.
Once screws are removed, begin by gently prying up in one corner using a spudge
Continue to center and then around to opposite side.
once all sides have been pried open, lift top half off
lift up power jack and remove from holding tabs
power jack removed
Hi!
Great instructions for the disassembly.
I’m trying to change the power socket for a new one and I would like to know how much long the wire has to be, first of buying it. Thank you!
crwdns2935229:011crwdne2935229:0
TY TY fixed myself for 7$
Should the new Power Jack look exactly the same as the manufacturer one? My original Power Jack has prongs but the new one does not and the laptop will not power on.
Does this require soldering as well ?
I would not rate this as a difficult task and I managed to complete the dismantle and reassemble within the 45 Minutes, Overall a pretty good description. The hardest bit was reattaching the wifi wires. I found I did not need tweezers and used a small electrical flat head instead of a spudge. No soldering or other tools. Having bought a new battery and charger (circa $50) the replacement part ($5) and this guide solved the issue. @gifts.fromgod my part was not identical (colour and size of the mid wire join) but fitted more or less and works a charm.
