Replacing the screen is a quick and easy task. Removing the screen only takes three tools: A JIS #0 screwdriver, a plastic opening tool, and a spudger. Before you start make sure you remove the battery and unplug the device.
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Once both switches are pulled, the battery should pop out.
Now you are ready to insert your new battery.
Use the plastic opening tool to pry the plastic away from the screen.
Carefully unsnap the front plastic piece to expose the frame of the screen.
Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
Slowly remove the sticker connected to the rear of the screen using a spudger.
Now you have removed the screen and are ready to install a new one.
Thanks alot…..I just fixed my screen by God's grace.
Hi! Is it possible to replace the screen with 1080p LCD?
