Lenovo Flex 3-1120 Speakers Replacement
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Geoff Bentz
crwdns2935283:003/09/16crwdne2935283:0
934 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 7-1, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S7G1
crwdns2942667:0crwdne2942667:0 497
