Lenovo Flex 3-1120 Network Card Replacement
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Network Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
Geoff Bentz
crwdns2935283:003/09/16crwdne2935283:0
934 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 7-1, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S7G1
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 879
