Lenovo Flex 3-1120 Hard Drive Replacement
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hard drive out from the computer.
Geoff Bentz
crwdns2935283:003/09/16crwdne2935283:0
934 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 7-1, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S7G1
How do you reload operating system.... for example windows 10?
supermac200 - crwdns2934203:0crwdne2934203:0
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - crwdns2934203:0crwdne2934203:0
Demo models of this do not have any SATA connector.
Elilla Shadowheart - crwdns2934203:0crwdne2934203:0
That sata connector is the worst thing ever
dilleremail - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,202
