Use this guide to replace the CPU in the Lenovo Essential G555-0873. This requires removing the back panel, removing the fan, and removing the heat sink. The only tool you need to complete these steps is the screwdriver listed below.
Unscrew the two 5.1 mm screws that secure the bottom cover.
Lift from the notch until the back panel comes up.
Disconnect the fan from the motherboard by pulling the plug shown in the picture.
Unscrew the three 4.6mm screws shown in the picture.
Gently lift the fan straight up until it is lifted out of the case.
Unscrew the four 7.3 mm screws shown in the picture.
Pull the heat sink assembly out of the laptop.
Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
