Replacing the DVD drive is easy to do. Before attempting to remove the DVD drive, remove the battery to avoid damaging the laptop.
Turn over laptop.
Switch open the left battery lock.
Hold the right battery lock open with one hand while removing the battery itself with the other.
Loosen the five Philips screws that secure the panel.
Prop open the cover with a plastic opening tool.
Unscrew the one 4 mm Phillips screw that is securing your DVD drive to the frame.
Grab your DVD drive and pull outwards.
