Lenovo Edge 2-1580 Storage Replacement
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery outward and remove it from the rest of the laptop.
    The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
    seattlehudson - crwdns2934203:0crwdne2934203:0
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement, Hard drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
    The hard drive can also be slid backward from the connection. Then the clips will clear and can be easily lifted out. Additionally, it disconnects the hard drive at the same time. This also keeps from possibly breaking the clips or damaging the drive by prying.
  7. Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Edge 2-1580 Storage Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully, using your hand, remove the hard drive from the laptop.
crwdns2935229:05crwdne2935229:0
Julian Escallon
crwdns2935283:009/27/17crwdne2935283:0
714 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S14-G1, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S14-G1, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S14G1
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - crwdns2934203:0crwdne2934203:0
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,216
