The guide will show you how to remove and replace the RAM module that comes with the laptop. Be sure the new replacement module is compatible with the motherboard.
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using a plastic opening tool, pull out the back panel from the laptop.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Pull the battery outward and remove it from the rest of the laptop.
The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
With both of your thumbs, gently pull both adjacent levers outwards. The RAM module will rise a bit.
Grab the RAM module , and gently pull it out.
What is the Max ram for this, and Can you do one where you replace the screen?
but how exactly do i open the cover?
