The guide will show you how to remove the motherboard from the laptop. The process requires a lot of disarming, and a place to safely deposit screws is recommended.
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using a plastic opening tool, pull out the back panel from the laptop.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Pull the battery outward and remove it from the rest of the laptop.
Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
Carefully, using your hand, remove the hard drive from the laptop.
Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
Grab the network card and gently pull it out.
Grab the black insulating tape and pull it out.
Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
Disconnect the fan from the motherboard.
Unplug the Fan connector from its socket on the motherboard.
Carefully remove the fan from the laptop.
Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
Disconnect these connectors from the motherboard.
Disconnect the four ribbon cables from the motherboard.
Unscrew and remove the (2) two Phillips #0 screws.
Lift up the black latch of the ribbon cable with the brown tab on top by holding the cable in to the motherboard.
Grab the tab with a pair of pliers and pull out the cable.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift the beige latch of the ribbon cable with the blue tab by holding the cable in to the motherboard, and with a pair of tweezers, pull out the cable.
Lift up the black latch of the ribbon cable with the blue tab at the lower right corner of the motherboard and disconnect it with a pair of tweezers.
Grab the tab and pull out the cable.
Locate the last ribbon cable with a blue tab and lift the beige latch holding the cable in to the motherboard.
With a pair of tweezers grab the tab and remove the cable.
Lift the black latch of the black connector at the top left corner of the motherboard by holding it in to the motherboard.
Grab the cable and pull it outwards to remove it.
Pull the wire besides the brown tab ribbon cable out and disconnect it.
Grab the small black connector by the RAM module and disconnect it from the motherboard.
Unplug the remaining connector besides the RAM module and remove it from the motherboard.
Gently grab the motherboard and pull it up lightly. Then pull it towards you and remove the motherboard.
